Industry Circles
Odyssey Audio
klaus@odyssey
Khartago LED
Khartago LED
0 Members and 1 Guest are viewing this topic. Read 1842 times.
Cacophonix
Khartago LED
10 Sep 2008, 06:16 pm »
The LEDs on one of khartago mono amps has been dead for some time. Does anyone know if this is something that i can find locally and replace it myself?
Haoleb
Re: Khartago LED
10 Sep 2008, 11:25 pm »
These are the ones I put in my Khartago's to replace the stock ones because they were too bright for me. I'm sure Klaus can also send you a couple.
http://www.mouser.com/Search/ProductDetail.aspx?qs=ek3FaJ1hxEWUC1pUHkY26g%3d%3d
zobsky
Fringe Lunatic - Dallas, Tx
Re: Khartago LED
Reply #2 on:
11 Sep 2008, 01:39 am »
A blue LED shouldn't cost more than a few cents . It's not an audiophile part etc .. You just need to check on the brightness spec / current spec and find something close. I'd replace both if I were you.
Industry Circles
Odyssey Audio
klaus@odyssey
Khartago LED
