Leopard does not recognize external burner
0 Members and 1 Guest are viewing this topic. Read 1129 times.
dB Cooper
« on: 9 Sep 2008, 01:05 am »
Does not see the device (Pioneer; the retail version of the SuperDrive) over either FW400 or USB. Have seen claims that 10.5 does not support external drives. Anybody know a workaround other than dropping a C-note for Toast?
yooper
Re: Leopard does not recognize external burner
« Reply #1 on: 9 Sep 2008, 02:59 am »
Hmmm... I have an external Lacie burner which works fine under Leopard.  I assume you have updated the drive with the latest software updates?  I would also recommend making sure you are running Apples latest 10.5.4 update as well.  The next thing I would do is trash the devices pilst (which is found under finder-user-library-preferences), and try again.
What happens if you put a cd or DVD in the drive?
Next up..With the devices plugged in, go up to the Apple menu and select about this mac-more info-disc burning. If it lists the drive as "unsupported" I'm not sure what you can do next.
I'll poke around the web and see If I can offer any more suggestions.
Mark
dB Cooper
« Reply #2 on: 10 Sep 2008, 07:28 pm »
Problem solved... *koff koff* operator error *koff koff*  :oops:
