Nuforce Version 9.2 Monoblocks - Sold
0 Members and 1 Guest are viewing this topic. Read 1809 times.
whell
« on: 8 Sep 2008, 03:59 pm »
These amps look like new, have original box and packaging, and work perfectly.  My system is getting down-sized due to financial needs, so unfortunately these, and a bunch of other gear, is going.  These are the all black version: upgraded Eichman cable pod speaker connectors. 190 WPC 8 ohm, 300 wpc 4 ohm.
    *       Power bandwidth: 100 to 20 kHz +/- 0.8 db 10 Hz -0.5 db 60 kHz -3 db
    *      THD+N = 0.03%, 1kHz, 10W
    *      Input impedance: 45K ohm
    *      Gain: 27 db
    *      SNR = 100 db at 100W
    *      Eichmann Cable Pod binding post for spade and banana plug (the plastic cap at the end of the binding post can be removed for connecting a banana plug)
    *      Chassis is made of high-grade anodized brushed aluminum to reduce audio resonance
    *      Dimension: 8.5" x 14" x 1.8" (height does not include feet)
    *      Worldwide AC voltage (84VAC to 264VAC). No need for AC regulator if the AC voltage falls within the specified range.
    *      Weight: 8 lb
$1400 plus shipping.
« Last Edit: 18 Sep 2008, 04:49 am by whell »
whell
Re: Nuforce Version 9.2 Monoblocks - Updated
« Reply #1 on: 11 Sep 2008, 10:05 am »
Bump
