Other Stuff
Archived Manufacturer Circles
Music Reference
New Russian EL84/6BQ5 = RAMLABS EL84 ?
0 Members and 1 Guest are viewing this topic. Read 3457 times.
6BQ5
6 Sep 2008, 11:54 pm »
I notice on the RAM Labs site that the current RAM offering for EL84's - 6BQ5 is identified as Russian made tube (perhaps SOVTEK?).
I'm curious whether these new TAD tube are the same?
Like this one...
http://www.cryoset.com/catalog/product_info.php?cPath=22_37&products_id=247&osCsid=3f41445796dee757a4b479172673dcfb
Which is actually a 6N14N-EB - supposedly Russian.
Or this one ...
http://www.cryoset.com/catalog/product_info.php?cPath=22_37&products_id=175&osCsid=3f41445796dee757a4b479172673dcfb
Which is actually a TAD-EL84-STR - also Russian made supposedly.
Or ...
None of the above.
My RM-10 currently uses 4 RAM EL84 tubes but am unsure of their origin. I also wonder if the above would be inter-changeable?
I would NOT buy the above CRYO versions though, I think cryo'd tubes are a waste of money. The TAD tubes above seem to be getting good reviews especially the STR one.
Last Edit: 8 Sep 2008, 05:02 am by 6BQ5
K.C.
Re: New Russian EL84/6BQ5 = RAMLABS EL84 ?
7 Sep 2008, 07:20 am »
My original RM-10 is still running original tubes. I assume they're the same as yours.
http://www.tubeaudiostore.com/6bq5.html
Roger A. Modjeski
Restricted
Reply #2 on:
16 Sep 2008, 08:11 am »
Cryo tubes make me
. They are a total waste of money and about the most foolish thing I can imagine.
6BQ5
Reply #3 on:
18 Sep 2008, 01:29 am »
Roger, these are also available in non-cryo version. Why am I not surprised that you focused on the cryo aspect?
Here's a link to the non-cryo version. Seems to be well constructed. Have you ever tried to test these?
http://thetubestore.com/tadel84.html
Last Edit: 20 Sep 2008, 05:00 am by 6BQ5
Roger A. Modjeski
Restricted
Reply #4 on:
11 Oct 2008, 06:49 pm »
Thanks for the link.
This tube appears to be a standard Chinese 6BQ5 by all it's physical characteristics. I have an identical Chinese standard 6BQ5 in my hand as I write this.
Other Stuff
Music Reference
