0 Members and 1 Guest are viewing this topic. Read 6424 times.
EAC USED to be harder to set up. Now it runs a wizard that's pretty tough to mess up. Using it once set up couldn't be easier.Bryan
Don't use the highest compression. It is a total waste of time (encoding time, that is) vs the little extra space it saves. -5 or -6is the knuckle in the time vs size curve...it's the right combo. See here:In the graphs, the Y-axis shows the compressed file size as a percentage of the uncompressed (wav) file size.The X-axis shows the speed, for example 10 means a 5 minute track was processed in 30 seconds.
In other words, there is no practical reason not to use max compression. On Debian Linux the default is max compression...for exactly these reasons.Darren
Bryan:Thanks for the response.My problem is, and I am not ashamed or embaressed to say this, that I am not a computer savvy guy. For some reason when I go onto the EAC website I stare at the screen and think to myself: "OK, not what do I do"!What I want to do is transfer all of my CDs onto an external hardrive and do the follwoing:1: I want to be able to burn CDs in exact duplicate form so that I can hear if a burned CD actually sounds better than the original copy. I have some blank Gold CDs that I would like to try.2: I want to make lossless copies so that I can steam to my Sonos system.3: I would like to have the Album art attached so that I can see it on my Sonsos controller.With these paramaters in mind (gulp) what do I do now? Is EAC the best program to use?I also read a new site called ComputerAudiophile.com and most of the guys write that iTunes is just as good as any of them and that one cannot hear any sound quality loss with iTunes compared to EAC, dbPoweramp, etc.I would aprreciate your's or anone's assistance. Please get me started!!
DBPower is the easiest solution, with the best quality, at a small price.EAC gives you same quality, not quite as easy to use, and free.iTunes is easy, free, and potentially not as good quality.If ease of use and quality is important - DB Poweramp.
can cds ripped with dbpoweramp but played-back through iTunes sound good?
