0 Members and 1 Guest are viewing this topic. Read 3703 times.
I haven't even settled on what type of speakers to use or which way to set up the room. Square one
The linked page says 38% from the rear wall is also a good spot, that would put my seat 7.4 feet from the front wall leaving more room to get the speakers out from the wall.
I'd like to have a two way that can get down to around 100hz and a sub that can be used below that if needed.
I'm going to get an ecm8000 this week to do room measurements, any links for beginners on that subject would be useful.
For the bass trapping I have two free floor to ceiling corners in the room, but they're opposite corners. Should I do corner traps there or something else?
thanks again for the suggestions everyone. So I have to get the microphone, probably thursday because the music store is open later then, and learn about bass traps. These use a membrane of some kind over the absorber material it seems?Ethan, I'm going to try fuzzmeasure since my laptop is an apple. I'll try to get the room cleaned out and learn to do some "before" measurements this weekend.
