Does this make sense?
zybar
« on: 11 Nov 2003, 09:17 pm »
In preperation for getting my Roompack + Seams from Nathan, I decided to get out my Rat Shack meter and Stereophile test cd to see where things are at now.
When I started my measurements, I had up my EchoBusters in the ceiling corners and on the rear wall to either side of my screen.  I also had in place three Roomlens' (one in the middle, and one to each side of my speakers).
Well, my measurements don't look that good and I can defintely hear some of what numbers suggest.
I have a suckout at 125Hz of roughly 6db's and I am positive 6-8db's between 80-50Hz.
In the midrange I am "relatively" flat with my worst reading being down 4.5 at 2000Hz.
In the upper frequencies I am not so good - between 3150-2000Hz I am at least 7db's down and at the very top almost 15db's down.
Wow, sounds like I really need help??
Well, when I listen to my system, I think it sounds pretty darn good (not bragging or being defensive).  When I have people over, they comment that it is one of the better systems they have heard.
How can this be?
I know the goal is to be as flat as possible across the board, but based on these numbers you might think the system should sound pretty bad.
Also, when I took down ALL of the room treatments and measured, things were only slightly worse from a numbers perspective.  I guess I was expecting a bigger deviation...was this wrong?
When I listen to music without the room treatments I do hear a drastic drop-off in the sound quality; it's just that the numbers don't seem to support it.
Will Nathan or somebody who really understands room acoutics shed some light on this for me?
Thanks in advance.
GW
Horsehead
« Reply #1 on: 11 Nov 2003, 09:32 pm »
Here is an article that might help you.  Also, they sell a test CD that has corrections for using the RatShack meter.
zybar
« Reply #2 on: 11 Nov 2003, 09:36 pm »
Thanks for the link...
That is exactly what I read and used for my measurements.
But that doesn't explain to me why the measurements did change very much when I compare room treatmeant vs no room treatment.
GW
Hantra
« Reply #3 on: 11 Nov 2003, 11:06 pm »
Well George. . . I wish I had an answer for you.
The short answer is, a flat frequency response is not a requisite to have good sound, and sound that is emotional, and pleasing to you.  I had a serious frequency suck out around 70 and a peak at 110 before Scott helped me fix it with his RTA.  Even so, I still had gobs of emotion, and very pleasing sound.
It just gets that much better when you do get those frequencies back that you're missing. . .
Let us know how your experience goes!
B
Rob Babcock
« Reply #4 on: 12 Nov 2003, 12:32 am »
It isn't just the frequency domain that the room treatments are working; a lot of it is controlling the reverberant signature of the room.
