Newbie mounting a cartridge??
0 Members and 1 Guest are viewing this topic. Read 2060 times.
S Clark
« on: 3 Sep 2008, 03:39 pm »
My JVC QL-F6 turntable arrived over the weekend.  I'll have to buy a headshell and cartridge- either the AT440mla or a grado green/blue.  What else will I have to buy to mount it properly? Also, there are some sellers that have the cartridge already in a headshell.  Would this be the way to go?
S Clark
Re: Newbie mounting a cartridge??
« Reply #1 on: 3 Sep 2008, 09:49 pm »
Still looking for advice.  Found this web site that was educational and a bit overwhelming- http://www.soundfountain.com/amb/ttadjust.html
TheChairGuy
« Reply #2 on: 3 Sep 2008, 10:18 pm »
Scott - PM'ed you back....not much I haven't experimented with on this deck.  You'll be fine - we'll get it up and running  :thumb:
John
Wayner
« Reply #3 on: 3 Sep 2008, 10:44 pm »
Twice in one night...gosh, as the Offical AT440MLa "pimp" I recommend this cartridge in spades. John will recommend the Grado and there you are, no better off then you were before!
Wayner  aa
S Clark
« Reply #4 on: 3 Sep 2008, 10:54 pm »
Actually, I have been looking at the AT as an option (based on your earlier recommendation- thanks Wayner).  My worry is that once I get a decent cartridge in, that without tools to mount it with, I won't get the best sound it has to offer.  What pitfalls do I avoid if I buy it already mounted in the headshell?
Wayner
« Reply #5 on: 3 Sep 2008, 11:17 pm »
Anyone can mount a cartridge into a headshell. Who says the premounted ones are put in correctly? I think we have enough "Masters" here to get you though setting up and aligning a cartridge.
Wayner
S Clark
« Reply #6 on: 3 Sep 2008, 11:38 pm »
Done.  I'll order tomorrow.
