0 Members and 1 Guest are viewing this topic. Read 7032 times.
Mark,I have a Goldpoint ladder attenuator and it does sound very nice. I have to disagree with Curt slightly. In some circuits the pop is more than slight. It seems to depend on how much DC is present in the source and how sensitive the input of the preamp is to DC. I do agree with him that ladder attenuators sound very good.I tried the Goldpoint in a Grounded Grid and the poppng was pretty loud. I can't say how many dB but it was loud enough to cause concern. One thing that will reduce or eliminate ...
Contact bounce when switching positions can cause a click to a pop depending on how long the bounce takes to happen. DC should not be present at the input of the pot as rotation of the pot across the switch contacts and the variation in resistance ratios modulates the DC present and gives you a signal to hear. The DC should have hit a blocking cap somewhere ahead of the pot. I have had excellent results with the Danish Audio ConnecT stepped attenuator in my projects. The resistors used are surface mount ...
Mark,Go with the 50K since that is what your pre is designed for. In many tube preamps the value of the input pot is what sets the input impedance. Since this is an active pre, the value of the input attenuator will have little if any affect on the output impedance. Mike G.
