PCB Board designer?
0 Members and 1 Guest are viewing this topic. Read 2153 times.
marchewd
PCB Board designer?
« on: 27 Aug 2008, 07:18 pm »
Hello,
    I am working on turning a schematic into pcb boards, but I do not feel comfortable doing that myself.  Does anyone know of anybody who does this, or can point me in the right direction.
Dan
whubbard
Re: PCB Board designer?
« Reply #1 on: 27 Aug 2008, 07:24 pm »
Hi,
I don't know of a person that will do it for you, but watch the designing PCB boards videos here, and I think you will be able to do it yourself. They are VERY good videos (and free).
Tangent Tutorials
-West
marchewd
« Reply #2 on: 27 Aug 2008, 07:31 pm »
I'll check them out!  Thanks.  I'm not looking for a hand out, as I'm willing to pay for someone's expertise.  The only PCB designers I found on the net were more computer designers and didn't really know much about audio.  I figured it would be better to find a fellow audiophile to help me out since I know they would take time and care to make it properly.
Dan
JoshK
« Reply #3 on: 27 Aug 2008, 08:11 pm »
Thanks West for the link.  I'll have to watch that later tonight as I'd like to understand PCB board layout better myself.  I understand the principal but there is a large gap between in theory and in practice.
Not to point you elsewhere, but I don't know many diy'ers on this forum that do much PCB layout work.  I could be wrong and they could be doing this on their own and not sharing here.  However, I think if you went to diyaudio.com you will find boatloads of diy'ers who layout pcbs.
marchewd
« Reply #4 on: 27 Aug 2008, 09:52 pm »
Josh,
    Thanks.  I have put a post over there as well.  So far, no response, but it's only been a couple of hours so far.
Thanks again,
Dan
cryoparts
« Reply #5 on: 27 Aug 2008, 10:56 pm »
If you use one of the more popular board houses, they supply you with free software that makes designing simple PCB's a snap.  Try:
http://www.4pcb.com/
http://www.pcb123.com/
You may be able to tackle the project yourself.
Peace,
Lee
JoshK
« Reply #6 on: 27 Aug 2008, 10:59 pm »
You might get more response if you mentioned for what purpose you intend to make a PCB.  There is a world of difference between tube amp pcb's and hi-speed digital circuits for instance.
richidoo
« Reply #7 on: 28 Aug 2008, 12:19 am »
Another diy with software and tips online.
http://www.expresspcb.com/
peranders
« Reply #8 on: 12 Jun 2009, 08:58 pm »
I'm a pcb cad pro, have done pcb's since the 80's. If it a small job I might help you. You can check my home page to see how my boards look like. At work I have done a 475 A pcb! Those were placed in a class D amp which delivered 55 kA and 220 kW power... water cooled.. big ... huge. So if you are after something powerful I might know how you should do.
