Niteshade Audio
0 Members and 1 Guest are viewing this topic. Read 1309 times.
Niteshade
    • Niteshade Audio
Niteshade Audio
« on: 23 Aug 2008, 10:52 am »
Niteshade Audio offers custom designed tube gear along with a lineup of standard favorites.
We design and manufacture the following:
1) Push Pull Amplifiers
2) Single Ended Amplifiers
3) Tube Preamps
4) Passive Preamps
5) Classic Series Amplifiers
Number five is a very popular item. Classic iron is used to make new amplifiers. Forget about restoration projects, since this is the best of both worlds. Something else: If the customer furnishes their own iron, we'll build a new amplifier around it. Supplying the iron saves money as well.
Web Site: http://sites.google.com/site/niteshadeaudio/Home
pardales
Re: Niteshade Audio
« Reply #1 on: 23 Aug 2008, 03:10 pm »
Welcome to AudioCircle!
pbrstreetgang
Re: Niteshade Audio
« Reply #2 on: 23 Aug 2008, 09:57 pm »
Any general descriptions or models to follow?
Niteshade
    • Niteshade Audio
Re: Niteshade Audio
« Reply #3 on: 23 Aug 2008, 11:41 pm »
The best way to find out what's going on is to look on my web site. There are a few products that will require writeups and that will be coming soon. Information is added to it all the time. Some of what I do can't be written up because the customer gets to request what they want and I build to their specifications.
Some examples of future products:
1) 813 Push Pull and Single Ended amplifiers
2) 572B based SET
3) 3-500ZG based ultra high power SET monoblocks
4) Hybrid amplifiers
Products that have already been made, but are not on the web site yet:
Preamp #1: An extremely versatile preamplifier that uses either 6L6 or 6V6 tubes in single ended configuration for its output tubes. The output is transformer coupled and extremely low impedance, 16 ohms to be exact.
Preamp #2: A three tube design using 6SN7 tubes. The circuit is extremely quiet, easy on the tubes and built for those who need multiple inputs.
100 Watt Monoblocks: Large, 17x10x6 inch amps using only five tubes total per amp to obtain very clean, detailed sound.
***I want to thank the folks who welcomed me here and helped me get started. You're all greatly appreciated!***
