Good soundbar for 42" flat screen
0 Members and 1 Guest are viewing this topic. Read 1910 times.
pbrstreetgang
« on: 22 Aug 2008, 08:31 pm »
The fiance wants the "surround sound" for the TV. Im pretty 2 channel only and dont care much to spend money on HT. Could anyone help with a simple, easy, and cost effective solution to this? Im not particulary talking about those "5.1 effect" soundbars but a LCR all in one for the front stage. I saw one that I thought was from ERA. I guess not as the site doesnt have it. I saw a Polk and Yamaha surround "5.1 effect" bar as well as Difinitive Solo and Mardant Short LCR. Anyone have any suggestions? Ive got a spare Panny XR25 I will set up for her.
So, It cant sound like those horrid HTIB because I have to endure it at times.
2) It has to be cost effective- if Im going to spend money its going to 2 channel or NOS tubes  :wink:
3) Easier the better, Im already looking at having to route wires through the walls and a few more is fine but Id like to still like her after her little present.
Thanks Guys and Gals
Red Dragon Audio
    • http://www.reddragonaudio.com
Re: Good soundbar for 42" flat screen
« Reply #1 on: 22 Aug 2008, 08:41 pm »
The Yamaha YSP models are a good value if you go with a previous version (say YSP 800 or YSP 1000).
Some are going for around $400 on eBay - then all you need is a good subwoofer and you're done.
I saw some wireless Boston Acoustic 8" subwoofers at Costco the other day for $199.
They'd make a great match and since they are wireless you can use multiple subs without having to run extra wires - they all run off the same wireless transmitter.
Ebay Auctions
Yamaha YSP website
Boston Acoustics 8" wireless subwoofer
pbrstreetgang
« Reply #2 on: 22 Aug 2008, 09:12 pm »
Thank you Ryan! I guess I could also not use the Panny reciever and just use this.
Any oter suggestions guys/
walkern
« Reply #3 on: 22 Aug 2008, 09:54 pm »
Paradigm makes an all-in-one LCR called the Millennia 20 Trio that is nice looking and good sounding, but it is a bit pricey (over a grand).  I heard one once in a store and was pleasantly surprised by the sound quality.  No digital trickery or phase shifting to attempt to create surround effects.  Might be worth checking out.
pbrstreetgang
« Reply #4 on: 22 Aug 2008, 10:29 pm »
Thats definitely worth looking into! Thanks
GerryD
« Reply #5 on: 22 Aug 2008, 11:38 pm »
Here's another source to investigate:
http://www.zvoxaudio.com/
