0 Members and 1 Guest are viewing this topic. Read 4640 times.
And your opinion, sir, is an underpriced joke. IMO, of course.
Quote from: Tyson on 22 Aug 2008, 06:41 amAnd your opinion, sir, is an underpriced joke. IMO, of course.And you keep sending Wayne those big checks, while I listen to the best for less.
bbaker,Any DAC is primarily 3 segments - Power Supply, D/A chip, and analog out. The D/A chip, not much to be done there, but the PS and the Analog out can both be improved a LOT on the Duet (and any mid-price DAC). Burson Audio makes a buffer that has been used w/the Duet/Squeezeboxes that was a big improvement to the analog signal, so Wayne (and mgalusha) put the Squeezebox (Duet) and the analog buffer into the same box, plus Wayne has developed a new analog buffer circuit designed specifically for this application to supercharge the analog output of the Duet (Squeezebox). Combined with the Power Supply upgrade, it addresses the weaknesses of the Duet. At least in theory (for me), since I've not heard the new Bolder Buffer yet. I have a feeling I'll not only be getting the buffer, but also the rebox as well. Man I'm so broke But I'm also so happy
Quote from: jhm731 on 22 Aug 2008, 09:08 amQuote from: Tyson on 22 Aug 2008, 06:41 amAnd your opinion, sir, is an underpriced joke. IMO, of course.And you keep sending Wayne those big checks, while I listen to the best for less. Have you compared Wayne's digital mods to Pat's mods in the same system, same room? If you haven't then you don't really know much, do you? (in your words)--Roy
Quote from: rajacat on 22 Aug 2008, 04:20 pmQuote from: jhm731 on 22 Aug 2008, 09:08 amQuote from: Tyson on 22 Aug 2008, 06:41 amAnd your opinion, sir, is an underpriced joke. IMO, of course.And you keep sending Wayne those big checks, while I listen to the best for less. Have you compared Wayne's digital mods to Pat's mods in the same system, same room? If you haven't then you don't really know much, do you? (in your words)--RoyAnd you've compared the expensive power supplies and mods to less expensive and you know that the more expensive is better? If you haven't then you don't really know much, do you?The same argument can be made either way.
