Piccolo mod suggestions?
0 Members and 1 Guest are viewing this topic. Read 1358 times.
nameci
« on: 20 Aug 2008, 07:07 pm »
I was wondering about improving my piccolo.
What are the modifications that would improve the sound of stock piccolo?  Any suggestion?
Theo
Re: Piccolo mod suggestions?
« Reply #1 on: 20 Aug 2008, 09:27 pm »
I've built a stock Piccolo as well.  I never bought the wallwart and am feeding it from a Bugle power supply.  As with most amp, it can benefit feeding better power.  My next step is to replace some caps.
hagtech
« Reply #2 on: 25 Aug 2008, 05:30 am »
Better caps will help.  The problem is finding something that fits.  Very tight inside the box.
jh
