Clockable soundcard for MAC PRO
0 Members and 1 Guest are viewing this topic. Read 2414 times.
wappinghigh
« on: 20 Aug 2008, 12:50 pm »
Steve...
I think I have found a 24/192?? capable soundcard that can be slotted into a MAC PRO, is compatible with OSX leopard and that can also receive a word clock input from an external clock (eg like your pacecar)...this looks extremely promising...
I'm doing a bit more research on this (it's the Lynx AES16e : PCI-Express version) and have asked Chris on computeraudiophile.com if he knows any more...but it has a very complicated digital output (8 channel via 4 XLR) (I think!)Not sure a very good setup for mere mortals!
BTW Chris's site is thoroughly recommended..great new post on setting up a computer server either PC or Mac Pro based...
P.S. can I also be put on the "overdrive" waiting list so I can drive your new DAC with this ultimate "paced" MAC PRO server!..that is if I can find some way of connecting it!
AB
audioengr
Re: Clockable soundcard for MAC PRO
« Reply #1 on: 20 Aug 2008, 09:30 pm »
Steve...
AB
That sounds really cool.  I have some customers with Lynx cards using Pace-Car with word-clock at 24/96.
If this is Alex, you are on the waiting list now.
Steve N.
wappinghigh
« Reply #2 on: 21 Aug 2008, 08:50 am »
Steve it is Alex, so thanks for putting me on the list.
I'm designing a new macpro server..and am contemplating using this card.
Still waiting from Chris re above points. In meantime concerning the "Overdrive"
1/ Will it do 24/192 straight through without upsampling?
2/ Does it have a pacecar built in ( I recall you were thinking of this with the Daytona)?
I definitely want an "overdrive", but not much point getting a 24/192 card if not useable with the "overdrive".
Might as well get a 24/96 card and clock that...
The other concern is the AES output on the card...but I have found a cable to interface this into a single AES input....the original F1 had an AES input. Have you dropped the AES/XLR input on the "overdrive"?
In any case this shouldn't matter, because the configuration I am planning is: Lynx AES16e<-> 24/192 Pacecar (connected via AES/XLR)<-> "Overdrive" (connected via I2S)...as long as the "overdrive" will do 24/192.....
send me a private email if you wish...
thanks again
AB
« Last Edit: 21 Aug 2008, 12:26 pm by wappinghigh »
audioengr
« Reply #3 on: 21 Aug 2008, 05:33 pm »
Yes, but not through the USB port (24/96 max).  There is no upsampling in the DAC.
No, it has I2S input to be used from an external Pace-Car.
Yes, no AES input.  There just isnt room on the backpanel for it, even replacing the S/PDIF RCA.
Steve N.
audioengr
« Reply #4 on: 21 Aug 2008, 05:33 pm »
wappinghigh
« Reply #5 on: 21 Aug 2008, 09:02 pm »
Unreal....
then Lynx AES16e<-> 24/192 Pacecar (connected via AES/XLR)<-> "Overdrive" (connected via I2S)..is "go for launch"!
Can you remember any Forum discussions re clocking a Lynx 24/96 card? Or links to owners who did this?? Will have to look into in more detail..
Thanks again...very exciting potential set up.
AB
audioengr
« Reply #6 on: 21 Aug 2008, 09:41 pm »
Unreal....
AB
Yep, this will work.
Steve N.
