McIntosh tweeter - what to do with it?
0 Members and 1 Guest are viewing this topic. Read 644 times.
dwarfed centipede
« on: 18 Aug 2008, 05:04 pm »
I found an old McIntosh tweeter off a 4-way floor speaker and it works great.  I was wondering what to do with it.  I tried looking up the model number, but I cant find it.  I was thinking about making it into a center channel speaker to go with my Infinity Primus series 6 1/2" bookshelves.  I hooked it up last night as a center and it is a little overbearing compared to the Infinity tweeters and doesn't match that well.  Do you think if I add a few 5 1/4" speakers and make a center channel speaker out of it that it would work good with my setup, or any other ideas what I should do with it?  I have the other tweeter's mate, but it doesn't work.  It needs the terminals redone, and I figured that would ruin the integrity of the speaker and throw off the theile/small parameters and probably not sound as good or match the other one.  Thanks for any input.
