0 Members and 1 Guest are viewing this topic. Read 6438 times.
I need to record NFL games that I cannot watch and thought a digital recorder would be better than using the VCR. But I keep seeing monthly charges required for their use. How do I find one that does not require this as I only need it during football season?
You can buy a stand alone DVR (Digital Video Recorder) that works just like a VCR. You can tell it to record channel --- at --:--am/pm for --- minutes.There's no service needed (like TiVo), since it's basically a glorified "alarm clock".There's 100 different ways to wire it into your system, but it should be pretty far "upstream" in your cable (coax) since it must have the ability to 'see' all of the available channels and change them as needed.Bob
Quote from: Bob in St. Louis on 18 Aug 2008, 03:18 pmYou can buy a stand alone DVR (Digital Video Recorder) that works just like a VCR. You can tell it to record channel --- at --:--am/pm for --- minutes.There's no service needed (like TiVo), since it's basically a glorified "alarm clock".There's 100 different ways to wire it into your system, but it should be pretty far "upstream" in your cable (coax) since it must have the ability to 'see' all of the available channels and change them as needed.BobCan you give me some brands or models to look at Bob? Everything I see is Tive this and Tive that.
Unless I'm the one that's confused, I don't think he's looking to burn DVD's. He's wanting a DVR that will store the program (football game) on an internal harddrive until he decides to delete it.Here's a good article explaining what DVR is, and what I think he's wanting;http://dvr.about.com/od/dvrs/a/capturemethod2.htmBob
Yup, sorry about. Seems the DVD/DVR combo is the prevalent way to do it nowdays. Bob
Quote from: Bob in St. Louis on 18 Aug 2008, 09:45 pmYup, sorry about. Seems the DVD/DVR combo is the prevalent way to do it nowdays. BobBig "downside" on these is that they are pretty much SD TV (480p at best)Plus they (as you or someone mentioned) don't have "schedules or grids" from which to program the recording. To really do it right you need to go HTPC, but then you are "bucks up" for a technology that will soon be overtaken with "online" options like VUDU, and other such On Demand services.It is only a matter of time and supertructure before "ALL" programming and video entertainment will be "On Demand" and or "Time Shifted" from online and not "stored" on your resident systemLotsa "kinks" but it is on the way aa.
you can purchase a high definition tivo box with lifetime service.
Quote from: John Casler on 18 Aug 2008, 10:02 pmQuote from: Bob in St. Louis on 18 Aug 2008, 09:45 pmYup, sorry about. Seems the DVD/DVR combo is the prevalent way to do it nowdays. BobBig "downside" on these is that they are pretty much SD TV (480p at best)Plus they (as you or someone mentioned) don't have "schedules or grids" from which to program the recording. To really do it right you need to go HTPC, but then you are "bucks up" for a technology that will soon be overtaken with "online" options like VUDU, and other such On Demand services.It is only a matter of time and supertructure before "ALL" programming and video entertainment will be "On Demand" and or "Time Shifted" from online and not "stored" on your resident systemLotsa "kinks" but it is on the way aa.How many decades are you thinking here John? The football season starts in a month.
