FS: B&W LCR3 2-Way Vented Center Channel Speaker $120 OBO
0 Members and 1 Guest are viewing this topic. Read 4058 times.
jlathe
Up for sale is a B&W LCR3 2-Way Vented Center Channel Speaker, in great condition.  Retails for $220.  Looking to get $120 O.B.O
Thanks for looking, and feel free to contact me with any questions
The tweeter uses tapering tube loading, first used in the original Nautilus. This ensures far greater absorption of unwanted radiation away from the rear of the diaphragm and results in a cleaner, more focussed and natural high frequency sound. The twin bass/midrange drivers use cones of woven glass fibre, which functions in a similar fashion to Kevlar.
The crossover components use air core inductors for lowest distortion and plastic film capacitors for minimal signal degradation.
The front baffle is moulded in inert mica filled polypropylene, which has a subtly curved outline and is dimpled to echo the theme of Flowport at the back; itself elegantly combined with easy-access terminal panel that can accept all common terminations. The LCR3 is magnetically shielded, which enables placement near a television.
Technical Specifications : LCR 3
Description   2-way vented-box system.
Dimensions   Height: 152mm
Width: 418mm
Depth: 221mm
Freq. Response   80Hz - 20kHz ± 3dB on reference axis
Freq. Range   -6dB at 60Hz and 30kHz
Sensitivity   90dB spl (2.83V 1m)
Normal Impedance   8 ohms (minimum 3.3ohms)
Power Handling   25W - 100W into 8 ohms on unclipped programme
Drive Units   Unit 1: 2x110mm (4.5") woven fibreglass cone bass/mid-range
Unit 2: 1x26mm (1") metal dome high-frequency
Unit 3:
Finish   Cabinet: Black Ash Vinyl, Maple VinylGrille: Black Cloth
jlathe
Re: FS: B&W LCR3 2-Way Vented Center Channel Speaker $120 OBO
« Reply #1 on: 25 Aug 2008, 02:30 am »
Sold
