The Music Circle
Rachmaninov - cello sonata
0 Members and 1 Guest are viewing this topic. Read 990 times.
Randy
17 Aug 2008, 03:04 pm »
With Gautier Capucaon and Gabrela Montero - Fabulous performance and recording. Just edges out the Truls Mork/Thibaudet benchmark edition, also on Virgin. The new recording has the edge in sonics, as well, but both are can't lose performances, and I will continue to listen to both. Capucaon's Prokofiev sonata has the edge over Mork's Myaskovsky's sonata since it is a superior work. Both discs also feature Rachmaninov's "Vocalise," in arrangements for cello and piano, naturally, but either of the Rach sonata performances are top recommendations. If ever a symphony was was written for just two instruments, this is it.
http://www.amazon.com/Rhapsody/dp/B000LPRNVI/ref=sr_1_4?ie=UTF8&s=music&qid=1218984891&sr=1-4
Last Edit: 17 Aug 2008, 05:36 pm by Randy
richidoo
Volunteer
Re: Rachmaninov - cello sonata
17 Aug 2008, 04:10 pm »
Thanks, reviews look great. It's in my Amazon shopping cart
Without music, life would be a mistake.
Reply #2 on:
17 Aug 2008, 05:50 pm »
I'm a big fan of both the Capucon brothers (their Brahms recordings are outstanding as well). I didn't know this was out, thanks for the heads up, order placed!
The Music Circle
