Straley Reality speaker cables...What did you replace them with?
0 Members and 1 Guest are viewing this topic. Read 6900 times.
Double Ugly
Is there anyway you can DIY the Remote Sense cables using Greg's speaker cables and a Neutrik connector?  You can pick up Neutrik connectors from Parts Express.
I'd love to find that's the case, but I don't think so.  I don't know what's involved with the "Remote Sense" part of the equation, which I suspect would be the long pole in the tent.
As for the Neutrik aspect, I'm having my speakers equipped with Speak-On connectors so as to have the same connection on both ends.  I know they aren't usually found outside of professional settings, but I'm convinced they're as good as anything this side of a direct connection.
FWIW, I recently gained a great deal more respect for Neutrik after hearing about the results of a certain manufacturer's comparisons.  This fellow can afford to use *any* connector with his new interconnect, and after exhaustive listening evaluations and comparisons, he found Neutrik's RCA connectors were the best, most neutral sounding he could find.
This fellow had nothing to gain except better sound quality, and I believe he was as surprised as anyone when the relatively inexpensive Neutrik proved the superior option.
