Adding DAC to B100
0 Members and 1 Guest are viewing this topic. Read 1578 times.
mpaulsen
Adding DAC to B100
« on: 16 Aug 2008, 05:03 pm »
I am planning on buying a B100 and would like to know if I buy the amp now how hard is it to add the optional DAC later? Is this something that I could just "pop" in or would it need to be taken to an authorized Bryston dealer or sent back to Bryston?
Mitchell
  • The Demo is Everything!
    • http://www.bryston.com
Re: Adding DAC to B100
« Reply #1 on: 16 Aug 2008, 05:26 pm »
Mitchell
Hi Mitchell,
The DAC is modular so it fits into a connector that is already installed in the B100. So you can do it in the field with some care for safety etc.
james
denjo
« Reply #2 on: 16 Aug 2008, 05:47 pm »
Mitchell
Good choice on the B-100!  :D
I bought the B-100 with Dac and phono and could not be happier!
niels
« Reply #3 on: 16 Aug 2008, 11:46 pm »
It is indeed very very simple! If I can do it the whole world can do it.
mpaulsen
« Reply #4 on: 17 Aug 2008, 11:17 pm »
Thanks for the help guys. I'm glad to hear that it's an easy upgrade.
-Mitchell
