FS: Sunfire Theater Grand II Architect Choice Preamp/Processor $700 NOW $650
0 Members and 1 Guest are viewing this topic. Read 1496 times.
vman71
Excellent condition and used only for watching movies on the weekend.  It comes with original box, glass shelf, manual, remote, stock power cord, and packaging.  It has kept and used in my dedicated audio room that is kids, pets and smoke-free.
Specifications:
Line Level Inputs
Sensitivity (for 0.5 V output): 125 mV
Sensitivity Phono: 1.6 mV
Frequency response: 20 Hz 20 kHz +/ 0.5dB
Signal to Noise (relative to 2V out):
Analog 97dB
Digital 105 dB
Distortion (THD): < 0.03%
Separation (at 1 kHz): 70 dB
Tone Control: Bass: +/ 10 dB Treble: +/ 10 dB
Audio Outputs
Frequency Response: Left and Right (Large): 20 Hz 20 kHz
Center and Surrounds (Large): 20 Hz 20 kHz
Subwoofer: 20 160 Hz (crossover set to 160Hz)
(The Sub plays the bass from the other channels using Bass Management)
Delay adjustment: Center: 0 25 mS Surrounds: 0 15 mS
(delay adjustment is automatic when speaker distance is entered)
Video Section
Video inputs/outputs: 1 Vp p /75 ohms
Component Bandwidth: 100 MHz, 1.5 dB
Composite Bandwidth: 6 MHz, 2 dB
S video Bandwidth: 18 MHz, 1.5 dB
FM Tuner Section
FM range: 87.5 108 MHz, 0.2 MHz steps (0.05 MHz for some export models)
Usable sensitivity (Mono): 1.6uV (75 ohms) 15.2 dBf (75kHz DEV,30dB)
50dB Quieting sensitivity (Stereo) 31.6uV (75 ohms) 41.2 dBf
Audio output frequency range: 30 Hz to 15 kHz, +.5dB, 3dB
AM Tuner Section
AM frequency range: 530 1710 kHz in 10 kHz steps (9 kHz steps for some export models)
Usable sensitivity (30% mod.,S/N 20 dB):16uV / (600 uV/m)
S/N (30% mod., 1 mV input): 48 dB
Trigger Outputs
12V Main and Zone2 Trigger current less than 500mA total
Main zone trigger relay contact rating: 24 VDC 2A maximum
Power Requirements
120 VAC 50 60 Hz: 40 W
Dimensions
17” Wide × 5.75” High × 16.5” Deep (Architect’s Choice)
Net Weight
22lbs. (Architect’s Choice)
Figure about $30-40 for shipping to the lower 48.
« Last Edit: 27 Aug 2008, 11:23 am by vman71 »
vman71
« Last Edit: 27 Aug 2008, 11:24 am by vman71 »
vman71
BUMP...I added a much better picture that I took last night.  As you can see, it's in pristine condition.  Kid, pet and smoke free environment.
At $650 for this preamp/processor, you will not find anything better and the fact that it is outstanding with 2ch music as well.
vman71
FINAL BUMP....Nobody wants to buy me? :cry:
