Open back
0 Members and 1 Guest are viewing this topic. Read 2662 times.
xecluded
Open back
« on: 9 Aug 2008, 08:00 pm »
Would speakers like these consider open baffle with the back open. They are only 6 1/2 deep. Dimension is 41" high, 21" wide and 6 3/8 deep.
MJK
    • Quarter Wavelength Loudspeaker Design
Re: Open back
« Reply #1 on: 9 Aug 2008, 08:34 pm »
In my opinion yes they would. You would need to factor in the depth during the design process but they would still behave as OB speakers.
Martin
xecluded
Re: Open back
« Reply #2 on: 10 Aug 2008, 05:24 am »
That's great.  I really enjoy reading your design by the way.  Many thanks Martin.
skite30
Re: Open back
« Reply #3 on: 10 Aug 2008, 06:25 pm »
Do you use these speakers close to the rear wall and if so how do you like them. I have always heard OB don't do very well unless out in the room at least 5 feet.
panomaniac
Re: Open back
« Reply #4 on: 10 Aug 2008, 11:26 pm »
What are the speakers in the photo above?
xecluded
Re: Open back
« Reply #5 on: 11 Aug 2008, 12:32 am »
They are Boston Acoustics A200 - sealed cabinets design.  They sound so good so I am thinking making some cabinets just like them with the back can be removed so I can try them "open baffle";  also plan to use the Alpha 15 instead of the 10" that they are designed with.
pbrstreetgang
Re: Open back
« Reply #6 on: 11 Aug 2008, 12:33 am »
I have nicknamed xcluded's chopp the MD Mullets  :thumb:
xecluded
Re: Open back
« Reply #7 on: 11 Aug 2008, 12:36 am »
"I  have nicknamed xcluded's chopp the MD Mullets "
 :green: :thumb: :green:
