Radio Shack 2-Way Die-Cast Mini-Speaker Upgrades Possible ?
0 Members and 1 Guest are viewing this topic. Read 1525 times.
eastein
OK, I bought these for a second system due to primarily to their very small size and in that context they are acceptable for a $60 pair of speakers.  Just for fun I tried them on my gaincard/msb gold set up in place of sehring 602's, a very revealing system revealed every fault.  Not a fair comparison at any level but revealing none the less.
Any suggestions on upgrading these speakers (cabinets) ? The boxes are aluminum rear ported, specs and link below.
>Eric
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F007%5F004%5F003%5F003&product%5Fid=40%2D5001
Radio Shack/RCA 2-Way Die-Cast Mini-Speaker
PRODUCT FEATURES
• Rated: 50W RMS/100W max.
• Size: 1” soft-dome tweeter
• Size: 4” cone woofer
• Frequency Repsons: 90-20,000Hz
• Sensitivity: 86db
• Impedance: 8
• Model # PRO-X44AV
Tonto Yoder
« Reply #1 on: 8 Nov 2003, 05:27 pm »
Back when the Minimus 7 was popular, there were modifications/tweaks circulating on the grapevine: some of them made the transition to the internet. You might search by "Minimus 7"?  It too had a 4" woofer, but was sealed.
Addendum: I believe it was AudioXpress that offered some tweak ideas for the minimus. Unfortunately, that material is scattered through a number of issues (which would cost more to buy than the speakers cost).
Maybe some of that info has circulated on the various forums.
http://www.audioxpress.com/magsdirx/spkrbldr/sbbilist.htm
