Aksonics up and running
0 Members and 1 Guest are viewing this topic. Read 1691 times.
cmscott6
« on: 8 Nov 2003, 02:29 pm »
Praise be to Hugh (and Ron).
Just finished my Aksonics, and they really are wonderful.  The depth and imagery is fantastic, as is the high end:  I've been entranced by the subtleties on cymbals, as well as upper harmonics on piano and guitar, that I hadn't heard before.  The mids and lows are great, though everything is still breaking in, so I suspect their character may change.  My main concern with low bass extension turned out to be a non-issue, as they reproduce lower register piano chords and acoustic bass notes quite well.  In all, highly recommended!
Anyone else have any experiences with tweaking the back panel/port size?
AKSA
« Reply #1 on: 9 Nov 2003, 02:35 am »
Hi Chris,
Thank you very much for your kind words!  I will relay your praise to Ron, who will be delighted!
I'm glad you mentioned the bass register, too.  I was well aware some would be more than curious about this aspect - it is a 6.5" driver after all - and it seems Ron has really delivered something which almost defies the laws of physics.
As you said, the standout is the imaging/soundstage, and the trueness of the harmonics of instruments like pianos and violins.  I'm delighted with my AKSonics (actually for the moment Ron and I share a pair which alternates between our homes) and I love the fact that we can adjust them to suit the room.
Would you be willing to consider writing a long term testimonial for the website?
Thanks again,
Hugh
rookster
« Reply #2 on: 9 Nov 2003, 09:43 pm »
Chris,
I have recently started my Aksonics project.  I am just waiting on the woofers.  I have narrowed down my choice of cabinet materials and finishes, but not yet committed to purchasing the wood as yet.  My veneering experise is the deciding factor on what I use.
What material did you use for the cabinets and what finish did you give them?  Any pictures?
I should have them up and running within a month as I have a few projects on the go.
I am looking forward to the improvement in my system.
cmscott6
« Reply #3 on: 10 Nov 2003, 02:24 pm »
Rookster,
I used 3/4" maple plywood and just finished with two coats of "Danish" wood oil - admittedly very spartan, but my flexirack and other pieces are all of that same construction.  I tend toward the minimalist look  :wink:
Sorry, I don't have a digital camera, but I'll try to scan some pics in soon.
Good luck!
Chris
