Introducing B-USB & B-USB Deluxe.... the new reference USB/SPDIF DAC - Preamp!
0 Members and 1 Guest are viewing this topic. Read 1788 times.
ASi_TEK
  • NO LIMITS!!!
    • www.asi-tek.com
New Innovative Product Release Announcement! Available Soon !
Introducing the ASi B-USB
B-USB is a completely optimized signature level battery powered USB/SPDIF DAC created for the discerning
audiophile seeking the ultimate listening performance and total value in mind. The B-USB is designed to seriously enhance any
two channel music system by offering the listener the most emotional, natural, and effortless musical presentation.
Hand-Built by the designer right here in the  United States of America to the highest level of quality and workmanship.
Since ASi Teknologies is a high end audio modification company, our B-USB product is built to the highest standards from the
ground up with no cost cutting or profit making mechanisms in place so you'll enjoy the maximum performance from this product.
Features-
~Digital Inputs- USB-B, RCA coaxial, Toslink
~Analog Outputs- RCA Female High Quality
Preliminary Technical Specifications-
USB-B input (both 1.0 and 2.0 capable)
Coaxial input, 75ohms, RCA or BNC connection
Toslink input
2-analog RCA single ended outputs
Output Impedance <1K ohms
Power Supply: SLA Battery Powered, Ultra Low Noise Regulated
Analog output stage- Completely passive, ultra fine quality transformer coupled, NO SIGNAL CAPACITORS OR RESISTORS!!
Analog output voltage- approx. 4v RMS
Typical play time: 80+ hours
Dynamic Range: 120DB
Dimensions: 17" Width x 15" Depth x 5" Height
Who needs B-USB?
Everyone! This product is designed to integrate into any 2ch
audio system. Example: Hook up your computer via USB,
iPod/Wadia 170i via RCA coaxial, CD or DVD player via Toslink.
Then you can feed the output to your preamplifier or integrated.
This product is the center and heart of your system! Its just that
easy!
Price- $1995 Shipped
Availability- September 2008
Introducing the B-USB Deluxe!
B-USB Deluxe is a completely optimized signature level battery powered USB/SPDIF DAC, digital/analog preamp, & headamp
created for the discerning audiophile seeking the ultimate listening performance and total value in mind. The B-USB Deluxe is designed to
seriously enhance any two channel music system by offering the listener the most emotional, natural, and effortless musical
presentation in your room or with your headphones!
Since ASi Teknologies is a high end audio modification company, our B-USB Deluxe product is built to the highest standards from
the ground up with no cost cutting or profit making mechanisms in place so you'll enjoy the maximum performance from this product
with no additional audio upgrades needed. No compromises!
Features-
~Analog Inputs- 6 Stereo RCA's
~Analog Outputs- 2 Stereo RCA's, One Fixed, One Variable
~24 turn step Volume Control with 0.05 DB turn stepping
~Selection Switch to use digital or analog signals
~Premium Headphone Output-
Will drive any headphone expect electrostatics. Works with all
functions and features of the unit. Fully optimized and battery
powered!
Toslink input
6-analog RCA single ended inputs
~Fixed RCA output is from DAC stage, bypassing volume control
for use into a amplifier or receiver with volume control.
~Variable RCA is output from internal volume control to directly
feed into a amplifier.
Input impedance 50K ohms
Analog output voltage- approx. 4v RMS or so when maxed
Preamp gain- up to 12DB over input
Who needs B-USB Deluxe?
audio system. Example: Hook up your computer, iPod/Wadia 170i,
digital transport, CD player, DVD player, phono stage, am-fm
tuner, etc. Then you can feed the output to any type of
amplification you might have. Whatever the output will be your
covered! With the premium headphone output your covered as
well to listen to the beautiful "mains free" music late at night while
the family sleeps. This product is the center and heart of your
system! Its just that easy!
Why choose B-USB Deluxe?
Simple!
B-USB Deluxe is designed from the ground up with performance,
NOT profit in mind!
~B-USB Deluxe is affordable!!!
We have not introduced any type of "dealer profit margin" or
"insane markups" in our pricing. Our beliefs is "performance before
profit". We don't have to pay an assembly line of workers.
Worldwide sales are factory direct, with no dealers to get in the
way. Each and every B-USB Deluxe is hand built with the highest
level of attention by the designer himself. This means that
production levels are going to be low, but the level of attention and
quality is at its highest!
~B-USB Deluxe has ultra low internal impedance characteristics.
The special SLA battery power source used in B-USB is 8-10
times lower in impedance factors over conventional SLA batteries
or even more so over those dreaded switching power supplies
thus resulting in a considerable improvement in speed, dynamics
and resolution!
~B-USB Deluxe has considerable long playing time.
80+ hours of play time is expected.. or play while the battery
system is charging.
~B-USB Deluxe has no external charging, everything is built inside.
No hassles with a charger connecting inline, just plug the power
cord from the power strip to the B-USB for charging the battery.
~B-USB Deluxe has ZERO capacitors in the signal path...
Its very simple, if you run the signal through a DC coupling
capacitor (even the highest quality version), your going to lose
performance. With no coupling capacitors in the signal path, we
can assure you the best level of detail and resolution possible.
~B-USB Deluxe has ultra low noise voltage regulation....
Instead of using low quality, industry standard voltage regulators
to regulate the voltage for the critical digital circuitry (to save
money and add in profit), we use ultra wide band ultra low noise
regulators which offer an absolute lower level of noise
characteristic.  Lower noise means much better performance!
~B-USB Deluxe has superior resonance control...
Now this one is very easy. The best sounding resonance control
for audio electronics is made from natural wood. If resonance
control is not correctly addressed, additional ringing and vibrations
are introduced to decrease the performance.
~B-USB Deluxe has no opamps....
Opamps have their place in use. Sometimes they are needed for
I/V applications or gain/buffer applications, this is fine for specific
designs. However with B-USB, those scenarios don't exist so we
can bypass that design approach for the best possible
performance.
~B-USB has no tubes! Completely passive transformer based!
The reasoning why we prefer ultra high quality signal coupling
transformer to tubed output section is we have found that the
analog output sections in and around the D to A stage of any
CD/DVD player or DAC is extremely sensitive to HF distortions
and mains pollution. Tube circuits are very prone to these
distortions. Also, what are the characteristics of vacuum tubes?
Distortion! Tube circuits require considerably more signal
parts, such as resistors and signal coupling capacitors
(which degrades signal quality), and they also require a socket.
Tube pins and sockets are prone to "oxidation" which limits
connectivity over time, slowly degrading the signal integrity.
Also, tubes throw off heat that can change the
performance of other critical local circuits by introducing "thermal
distortion". We understand audiophiles love for tubes (and we feel
they have their place for use), however we have a much better
sounding approach in this design.
Performance will be unmatched!
Price- $3495 Shipped!!!
Projected release September 2008.
Prototype in testing right now.
Future Stereotimes review coming!
If you have interest in either of these incredible products, or would like to know more information, or sign your name up on the pre-order list please email us at [email protected] or PM us and we can give more detail. These products are all about performance in mind, nothing else!
Pictures and website pages are in the works....
