Cheap high efficiency OB driver for T-amp boombox?
0 Members and 1 Guest are viewing this topic. Read 4869 times.
bundee1
I basically want to screw a pair of drivers to a piece of wood and hook it up to a T-amp and an Ipod shuffle. Any suggestions?
Russell Dawkins
Re: Cheap high efficiency OB driver for T-amp boombox?
« Reply #1 on: 4 Aug 2008, 07:03 pm »
tempting ...  :D
opnly bafld
« Reply #2 on: 4 Aug 2008, 08:43 pm »
Hawthorne Audio SI 15"
6x9carspeakers
« Reply #3 on: 4 Aug 2008, 09:53 pm »
on the cheap? try some 6x9 car speakers!!!!!!!!!! :icon_lol: aa :oops: :D
mca
« Reply #4 on: 4 Aug 2008, 09:59 pm »
Are you going to carry this around on your shoulder? If so, the 15's may be a little large  :lol:
bundee1
« Reply #5 on: 4 Aug 2008, 11:14 pm »
what about the visaton b200? can they be driven by a 6 watt t-amp?
Wind Chaser
« Reply #6 on: 5 Aug 2008, 12:50 am »
Yes they can, but what T amp are you specifically referring to?  On the cheap side I'd go with used car audio speakers
opnly bafld
« Reply #7 on: 5 Aug 2008, 12:52 am »
Yes, but they are not going to boom by themselves.
Lin
bundee1
« Reply #8 on: 5 Aug 2008, 12:56 am »
any more specific advice? how would I make it boom or just sound good?
dyohn
    • the12volt.com
« Reply #9 on: 5 Aug 2008, 01:01 am »
What exactly do you mean by "boom"?
bbaker6212
« Reply #10 on: 5 Aug 2008, 01:07 am »
won't boom (have good bass) unless you use one or more very large drivers. The Hawthorns are the way to go.
opnly bafld
« Reply #11 on: 5 Aug 2008, 01:08 am »
The Hawthorne's are the only drivers I know of that you can throw on a piece of wood and have them sound good, all the others I know of take a little more work and usually need bass helper drivers.
Lin
bundee1
« Reply #12 on: 5 Aug 2008, 01:28 am »
will the visaton run open baffle sound better than a boombox? I have the sonic impact 2nd gen t-amp. what if I have to box them? any cheap enclosure solutions. this will basically reside on a desktop or in the kitchen.
opnly bafld
« Reply #13 on: 5 Aug 2008, 03:18 am »
In this application for a little more than the price of a pair of B200s I would try something like these:
http://fritzspeakers.com/FullRangeSpecs.htm
Lin
panomaniac
« Reply #14 on: 6 Aug 2008, 12:02 am »
Getting a decent bass from small OB and the super-T is going to be hard.  And I should know!  You can get great midrange, tho...
http://www.michael.mardis.com/sonic/start.html
I would go with one of those designs linked to in the post above.
Wind Chaser
« Reply #15 on: 6 Aug 2008, 01:00 am »
Micheal,
Do you have any experience or thoughts with the DIY Paradise Charlize?
JeffB
« Reply #16 on: 6 Aug 2008, 01:55 am »
Some people have liked a B-200 stand alone on large baffles.
I have a B-200 on an 18" wide baffle.  I would find this unlistenable without a large helper woofer.
Even then the driver is peaky and needs equalization of some sort.
Since you want this on a desktop, I think you will want a smallish baffle, and thus you will have no bass below 150Hz and it will not sound good.
I drive the B-200 with a Clari-t(a modified T-amp).  I can get 90db @ 10 feet no problem.  It is plenty loud.
You might want to take a look at this link.
http://www.tnt-audio.com/casse/t-speakers_e.html
Those Fritzspeakers might be nice.  They look like some older Omega speaker designs.  The Omega line is now more money.
http://www.omegaloudspeakers.com/products.html
panomaniac
« Reply #17 on: 6 Aug 2008, 08:47 pm »
A little OT, but yes, the DIY Paradise Charlize is a very nice amp.
The original is basically the Tripath eval board rearranged.  It works well.
I have not heard the new version, but have been told it is even better.
The TA2020 is probably my favorite Tripath chip.
