HELP ... 3B SST won't turn on!!!!
0 Members and 1 Guest are viewing this topic. Read 2684 times.
ChrisBo
« on: 3 Aug 2008, 04:37 pm »
Hello Everyone, my 3B SST will not turn on ... I was using my stereo last night for an hour or so with no problem ... today there are no lights and I have tried turning the unit off for 10 min although, it did not power up again ... any thoughts???
Thank You.
  • The Demo is Everything!
    • http://www.bryston.com
Re: HELP ... 3B SST won't turn on!!!!
« Reply #1 on: 3 Aug 2008, 05:12 pm »
Thank You.
Hi,
Check the circuit breaker on the back has not disengaged.
Check the 12 volt trigger switch on the back is in the LOCAL position
james
ChrisBo
« Reply #2 on: 3 Aug 2008, 05:40 pm »
Hello James, thank you for the quick reply it is greatly appreciated ... I double checked and both switches are in the correct position ... any other ideas?  Or should this go into service ... I live in Brampton, Ontario.
« Reply #3 on: 3 Aug 2008, 05:45 pm »
Only other thing I can think of is bad power cord.
james
jethro
« Reply #4 on: 3 Aug 2008, 06:07 pm »
Electrical circuit fuse / breaker ?
Loose power cord ?
b5pt9
« Reply #5 on: 3 Aug 2008, 06:49 pm »
Have you tried using the 12V trigger to see if it powers up this way?  If so this would isolate the problem to the membrane power switch on the front.
niels
« Reply #6 on: 3 Aug 2008, 07:00 pm »
With jethro, fuse in amp has blown for some reason maybe.
jethro
« Reply #7 on: 4 Aug 2008, 12:11 am »
Actually I was referring to the fuse/breaker box for the wall plug.
ChrisBo
« Reply #8 on: 5 Aug 2008, 12:36 am »
Hey there, yes I did check that as well ... I sent an email to Bryston service for some direction ... my stack of new cd's will have to wait for now  :?
