0 Members and 1 Guest are viewing this topic. Read 11730 times.
ro7939: I've read about the multiple subs approach and am definitely intrigued, but would like to know if there is a certain frequency or range that you must crossover at. I understand Geddes' designs employ a relatively high crossover point of around 80-100hz or so, but am wondering if that's only because his summa kits roll off at that frequency. For instance, I don't suppose one could combine Geddes' approach with that of, say, REL, that to my knowledge espouses introducing the sub at the natural roll off point of the main speakers without removing their low frequency information?Also, would any sub and plate amp suffice, or would you need an amp that employs a certain type of crossover, like a fourth-order? I've been considering running two or more of the GR Research subs eventually, but in any case will have to hold off for now since I live in an apartment and have nowhere to do any woodworking.
I understand Geddes' designs employ a relatively high crossover point of around 80-100hz or so, but am wondering if that's only because his summa kits roll off at that frequency. For instance, I don't suppose one could combine Geddes' approach with that of, say, REL, that to my knowledge espouses introducing the sub at the natural roll off point of the main speakers without removing their low frequency information?Also, would any sub and plate amp suffice, or would you need an amp that employs a certain type of crossover, like a fourth-order? ...
