Please suggest decent interconnects/component video cables
0 Members and 1 Guest are viewing this topic. Read 3205 times.
jqp
I need to get 5 interconnects from the OUtlaw 950 to 5 amps.
Also need Video Component cables.
Which are decent, which to avoid?
And should I just bypass the Outlaw for video with only the one Sony TV and one XBox (as DVD player for now)?
« Reply #1 on: 6 Nov 2003, 07:54 pm »
Bolder cryo'd M80's are my favorite inexpensive IC's, and are what I use in my HT setup.
F-100
« Reply #2 on: 6 Nov 2003, 08:13 pm »
Belden 89259 based cables with Eichmann Bullet IC  from http://www.heartlandcables.com/
For $50 a pair, this is the best deal that you can find. The Eichmann bullet alone already cost $30.
rosconey
« Reply #3 on: 6 Nov 2003, 09:15 pm »
ha ha  i've been thinking about heartland cables, the price is too good to miss, 30$ for the plugs and the belden is about 1.50 a foot.
its not worth diy at this price
 :mrgreen:
F-100
« Reply #4 on: 6 Nov 2003, 09:22 pm »
I bought several pairs from Dan and he is a very nice guy to deal with.
How do they sound?  Just do a search for "Belden 89259" at AudioAsylum and you'll find tons of them.
« Reply #5 on: 6 Nov 2003, 10:18 pm »
WOW, Dan needs to advertise more.  Great prices on some nice cables.
Juan R
« Reply #6 on: 6 Nov 2003, 10:25 pm »
the outlaw IC are not to bad for the price.
Rocket
Another Great Deal
« Reply #7 on: 6 Nov 2003, 11:37 pm »
Hi,
Thanks for the link to Heartland Cables.
You guys don't know how lucky you are, in Australia 4 eichman bullet plugs alone cost $80au.  Heartland are selling 3 foot pair for cheaper than this.
I will be in contact with them.
Btw how did they sound in comparison to other cables?
Regards
Rod
jjb
« Reply #8 on: 7 Nov 2003, 03:25 am »
Go with ehe belden for audioasylum their sonic quality is great, they also have great speaker cables :D
Mark Rich
« Reply #9 on: 14 Nov 2003, 12:51 am »
While I like how the eichmann plugs sound I'm always concerned when they are matched with a thin and stiff cable.
FYI Signalcable.com also sells this combo.
Also check out RhinoCables.net for 89259 and Vampire combo
Otherwise you cant go wrong with Bolder
ton1313
« Reply #10 on: 14 Nov 2003, 11:54 am »
The best component video cable I have used is the Megular from Zu Cable. I tested it against a Belden component from RS Cables, & the difference was like taking a pair of sunglasses off. With the Zu, the colors just jump off of the TV. They sometimes run them for auction on ebay.
Later
RooX
« Reply #11 on: 14 Nov 2003, 04:54 pm »
i have just finished burning in a set of xlo component cables.. so far: VERY IMPRESSED.  might be an option for you.. they list for around $100us
cheers
colin Hill
  • Speakers....What Speakers ?
« Reply #12 on: 15 Nov 2003, 06:20 am »
Quote from: F-100
For any Ebay'ers... Heartland runs auctions there, price starts at $50.00 - other cables offered also. All positive feedback. link   >> http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3059142933&category=33205&rd=1
