0 Members and 1 Guest are viewing this topic. Read 3699 times.
Well said. If you have the space, a mix of absorbtion to deal with decay times, early reflections that are out of time and usually have poor frequency response, and general cancellations in the bottom end - coupled with selective diffusive elements to restore some of the ambient cues can be a very nice solution. The trick is to get things balanced and have diffusion far enough away to be effective. Remember that diffusion can act both in the physical domain and the time domain.Bryan
....Anyway, the panels do ring when you rap 'em. I know some have damped them with spray-on bed-liner type goo.Is there a specific product that can be recommended for this? Thanks!-Mike
Years ago I remember having the same reaction as you Tan, thinking initially (first few minutes) that things sounded less lively or exciting but you learn and adapt quickly. Now it's hard to listen to the untreated room.
