Can I SB2 - FW15 - SqueezeCenter - Inguz?
0 Members and 1 Guest are viewing this topic. Read 1635 times.
jkelly
« on: 27 Jul 2008, 04:16 pm »
Before I break everything, is the SB2 capable of all this?
Jeff
gitarretyp
Re: Can I SB2 - FW15 - SqueezeCenter - Inguz?
« Reply #1 on: 27 Jul 2008, 05:34 pm »
I don't think inguz is compatible with fw15, at least it wasn't last time i used them.
chadh
« Reply #2 on: 28 Jul 2008, 03:16 am »
Up until this weekend, I had been using SlimServer with firmware v.15.  I had also, for a while, used the Inguz plugin successfully with that setup.  I have no idea how things might have been different if I were using SqueezeCenter.  I've only just changed to SqueezeCenter, but I also updated the firmware to the lastest one and I no longer use Inguz.  So I'm not sure whether my experience is of any use to you at all.
Chad
