Plitron transformers in Bryston amps
0 Members and 1 Guest are viewing this topic. Read 2585 times.
denjo
« on: 25 Jul 2008, 02:46 am »
Hi James
The 28BSST uses the renowned Plitron transformers. I wonder if Plitron transormers are also used in your other amplifiers, including the transformers for the digital part of the circuitry. Being a Canadian company, and I think not too far from Bryston's factory in Ontario, it would make good sense to use their excellent transformers and at the same time lend support to Canadian industries. Looking back at my acquisitions, I have no less than 3 excellent audio products from the land of the Mapletree - Black Sand power cords, Bryston and Bent Audio's TAP TVC. Plitron would make it four!
Best Regards
Dennis
  • The Demo is Everything!
    • http://www.bryston.com
Re: Plitron transformers in Bryston amps
« Reply #1 on: 25 Jul 2008, 09:58 am »
Hi Dennis,
Yes most of our transformers are proprietary designs and made custom for us by Plitron- including the transformers used in the Torus products.
james
vegasdave
« Reply #2 on: 26 Jul 2008, 02:18 am »
Thanks for the info, James. Are these transformers a big contributor to the Bryston sound?
« Reply #3 on: 26 Jul 2008, 10:42 am »
Yes it is certainly a big part of it.  Power supply design is critical in all products including our CD Player and DAC and preamps.
james
vegasdave
« Reply #4 on: 26 Jul 2008, 11:01 am »
