Audio/Video Gear and Systems
The Vinyl Circle
woodsyi
Pulley upgrade ? for Chris
0 Members and 1 Guest are viewing this topic. Read 2192 times.
audiot_savant
5 Nov 2003, 11:22 pm »
Hi Chris,
I own a Eurolab Premiere/Scheu. Just a shot in the dark here, do you have any idea if your pulley upgrade will fit my TT?
If you don't know that offhand, can you tell me what diameter of motor shaft the pulley will fit?
Best regards,
Randy
cbrady
6 Nov 2003, 03:28 pm »
The Maxon motor we use has a 3mm shaft. I think that the Eurolab motor has a
2mm shaft. If so the pulley will not fit.
Chris
The Vinyl Circle
woodsyi
