BRUS260 EDI Bridge
0 Members and 1 Guest are viewing this topic. Read 3110 times.
Harmon
BRUS260 EDI Bridge
« on: 5 Nov 2003, 07:48 pm »
Hi Guys
     I am looking to purchase 2 BRUS2 rectifier bridges? Thanks
Monolith
Re: BRUS260 EDI Bridge
« Reply #1 on: 6 Nov 2003, 04:13 pm »
Quote from: Harmon
Hi Guys
What leads?  M?  W?
Occam
BRUS260 EDI Bridge
« Reply #2 on: 6 Nov 2003, 05:20 pm »
on order @ Richardson Electronics
http://catalog.rell.com/rellecom/scripts/SkuPage.asp?SKU=337030&PNO=&PNM=
at those prices, $11+ for either the lug or wire terminated, if you've the room and inclination, consider making your own bridge from Fairchild Stealth(tm). Either 4 single diodes, or one common cathode dual and 2 singles.
The EDI bridges are an untested component, the Fairchild Steaths are superb....
http://www.newark.com/product-details/text/CD121/74262.html
Occam
Monolith
BRUS260 EDI Bridge
« Reply #3 on: 6 Nov 2003, 05:27 pm »
The other component he's looking for is a military temp range part (1N4773A), so my curiosity is piqued as to what equipment these are for.
Harmon
« Reply #4 on: 6 Nov 2003, 05:33 pm »
Quote from: Monolith
Quote from: Harmon
Hi Guys
What leads?  M?  W?
Hi Mon
     The specific EDI bridge number is BRUS260 which is a 600 volt bridge. Very hard to find when you just want to purchase 2.
      I am building a preamp for a second system.
      I found the 1n4773a.
Monolith
BRUS260 EDI Bridge
« Reply #5 on: 6 Nov 2003, 05:49 pm »
Quote from: Harmon
Hi Mon
As Occam linked above, Richardson carries them.  I would suggest, if you have the room, trying out the discrete Stealth diodes.  Do you really need 9amp rectifiers for your preamp?  Mind if I ask where you located the temperature compensated zener?
Harmon
Bridge
« Reply #6 on: 6 Nov 2003, 06:18 pm »
Thanks Monolith and Occam, you guys were very helpful.
_scotty_
BRUS260 EDI Bridge
« Reply #7 on: 8 Nov 2003, 03:51 am »
Harmon is building a Stan Warren dual mono buffer like mine. A ten amp bridge is a good thing in this application, the bigger the amperage rating on the bridge the lower the power supply impedance will be. In other words the bridge won't be a choke point for current or voltage delivery in volume or speed. With a properly constucted supply and board layout, this buffer has a greater than 30mHz bandwidth, superb settling time and slew symetry,with .003 THD+N
Harmon
BRUS260 EDI Bridge
« Reply #8 on: 8 Nov 2003, 03:11 pm »
Quote from: _scotty_
Will any ten amp bridge brand be good for the sonics or will a specific well tested (sonically) brand work better.
