0 Members and 1 Guest are viewing this topic. Read 3892 times.
Wouldn't the HDTV have more source resolution to play with than your OPPO, even though in your case its down converting? I mean, isn't the OPPO playing standard def DVD's at basically their standard resolution, while with your HDTV it has more information from the start?
I have found this to be true as well. I am no expert but I believe a lot of it has to do with the HD standards that are in place. It is my understanding that there is a strict standard for HD that the older NTSC (never twice the same color ) lacked. Also, remember that the live sports HD broadcast are using HD cameras, so the entire process is produced at a higher standard with regard to color, brightness, contrast, etc. as well as higher resolution. That's my take on it anyway.Best,Ed
DVD is heavily compressed when it is MPEG 2 coded. That means when you replay it at native resolution, you will be seeing compression artifacts such as codec noise, macro-blocking, image softening and general loss of resolution and quality. These effects will be especially obvious where there is lots of motion. Thsi means DVD cannot resolve all the detail in the original 720x480 image. BD & HD is compressed as well (more if anything, though the codecs are better) and is similarly incapable of resolving all its native 1920x1080 resolution. However, it is far better at resolving all the detail replayed in an SD display. So its all down to resolution loss with compression. Nick
