Ethan's Membrane Traps
0 Members and 1 Guest are viewing this topic. Read 1773 times.
Syrah
« on: 19 Jul 2008, 01:48 pm »
Question for the group.  Are Ethan’s wood membrane traps still generally advocated here?
I have two windows that I’m thinking of covering up – with the added benefit of reducing my AC consumption.
My plan is as follows:
1)   Screw a wooden frame around the window frame.
2)   Fill the window inset with insulation – 6 inch thick insulation.
3)   Staple down chicken wire on to the wooden frame, squishing the 6 inch insulation down to 3½ inches.
4)   Put another wood frame on top of the first wood frame to create a ¾ inch gap, caulking in between.
5)   I would then caulk and screw a ½ inch thick, 4’ * 8’ plywood panel on top.
Would this work well?
Are there any changes that could make this a better trap?
I live on an island where 703 and 705 are difficult to get.  I read that 703 has about double the density of the fluffy stuff, and 705 is double that.
I suppose I could create some room behind the insulation by going – window, gap, chicken wire, insulation, more chicken wire to squish the insulation, gap, plywood.
Ethan Winer
  • Audio expert
Re: Ethan's Membrane Traps
« Reply #1 on: 19 Jul 2008, 03:23 pm »
Wood panel traps are great, but more for large rooms. For most domestic size rooms I prefer fiberglass-based traps.
I don't recommend that. Wood panel traps need a rigid sheet rock wall behind them.
You can get similar results using fluffy fiberglass compressed to be thinner. That is, R38 which is 12 inches thick, when compressed to be 4 inches thick, is similar to using rigid fiberglass.
--Ethan
Syrah
« Reply #2 on: 19 Jul 2008, 03:43 pm »
Great.  Thanks for your prompt response Ethan.
Syrah
« Reply #3 on: 19 Jul 2008, 06:38 pm »
Sorry.  One more thing.  If I build panels by squishing 12" of fluffy between chicken wire and wooden frames, what material should I face it with for the part facing the room?  I was thinking of a plastic sheet, should I be using something else? Paper, foil?  Thanks!
