TAS Reviewer Feud?
0 Members and 1 Guest are viewing this topic. Read 1363 times.
jhm731
TAS Reviewer Feud?
« on: 17 Jul 2008, 09:06 pm »
See JV's comments about REG on P.106 of the 8/08 issue.
If you don't get TAS, you can see JV's comments here:
http://www.audiophilesystems.com/data/dCS%20Reviews/48038_eprint.pdf
sbrtoy
Re: TAS Reviewer Feud?
« Reply #1 on: 17 Jul 2008, 11:25 pm »
There is plenty of commentary on the web about Mr. JV as well...most all is negative.
Imperial
  • Love keeps us in the air, when we ought to fall.
« Reply #2 on: 18 Jul 2008, 09:43 am »
Then those commentary's shall stay were they are.
Procedure dictates that they do... just reminding about this  :wink:
Imperial
Imperial
« Reply #3 on: 18 Jul 2008, 10:10 am »
On the subject of this feud.
I don't think it is a feud, it's only a part of the "compression wars".
JV has some years ago voiced worry about the ipod negative effect on resolution and that
the music industry seem to stop making good recordings all together...
So, analog, by nature has "resolution" , and digital has "perfect" math as he says it.
This is a slight kick towards REG, who plays the Violin... and should be very able to hear
what JV is implying...
This sarcasm mixed in with irony and no feud... :roll:
It's an angle of attack, defending ones views on the "format-wars" if you may.
After all this is a review, that end with an admission of the fact that JV does see REG's point about
digital isn't half bad after all.
JV then agrees and points out that he doesn't usually give two thumbs up for a digital component..
He normally thinks it can't really compete with analogue... but this DCS... oh that is to close for comfort.
Hence the start of the article.. that is sort of a war cry for analogue.. not against REG...
Yes? That's what I got out of it anyway.  :oops:
Imperial
jhm731
Imperial
« Reply #5 on: 18 Jul 2008, 05:46 pm »
AES talks.. that never leads down a good path if you ask me... :?
I'm out of this thread right now... G'day..
Imperial
