0 Members and 1 Guest are viewing this topic. Read 26839 times.
So which GIK treatments are you adding and where are you putting them?
Watch the drapes. While we need to deal with light from a video perspective, we also need to maintain good left to right symmetry for general audio whether it be HT or 2 channel.Bryan
Not necessarily. Glass and drywall will both reflect pretty much the entire spectrum but bass will pass easier through the glass and that isn't going to change. However, curtains on one sidewall will absorb a lot of upper mids and highs where the drywall won't. If you want to keep it relatively the same, you could do a blackout shade with wood slat blinds in front of it.Bryan
I am dealing with Bryan also and it has been fantastic- will be ordering as soon as Mr Bush send me my check!!
Very nice. The room is looking good and I like your photography.
Not sure what's up with the Monsters. Please take a few pics if you can and email them to me.
You're correct in how to hang them horizontally. You really don't need a ton of slack. ou can try double hooks if you're more comfortable with that method though.
We're very tight on space to do everything you want in this room. You're already very nearfield which is fine - just not sure how the hemps handle that being that far apart relatively.
As for the sub, I'd likely start with it maybe 3/7ths of the room width along the front wall. Maybe pull out 1' or so. This is just a starting point. I'd love to do it in the rear of the room but I don't want to introduce any discontinuity for 2 channel. No idea where you're crossing over either and if you have the fronts actively cut off or not.
Hang in there, we'll get it all sorted.
