Stillpoints ERS Temperature rating?
0 Members and 1 Guest are viewing this topic. Read 1506 times.
Hantra
« on: 4 Nov 2003, 10:36 pm »
Does anyone know the rated temperature of this stuff?
I want to put it on the inside of my DAC, but I don't want to burn down the house.  How close can I put it to the tube, which sticks out of the chassis?
B
_scotty_
« Reply #1 on: 5 Nov 2003, 02:54 am »
Hantra call up the folks at Stillpoint and ask them your question. They were very helpful to me when I called requesting product information.
Gordy
« Reply #2 on: 5 Nov 2003, 03:17 am »
Hi Hantra,
Don't know the tube(s) you use, but the skin temp of a 12ax7 used for line stages is about 75 to 90 deg. C, a 12au7 used for power is 95 to 120 and an EL 34 will run 220 easy.  Temps fall off very quickly, maybe 20 degs within a 1/4".  Dacron/polyester (in general) will start to tack up at about 110 to 120 deg. C and is melting (flowing) at 140 to 170.  Hope this helps...
Gordy
cryotweaks
  • Funny name. Serious audio.
    • TweekGeek.com
« Reply #3 on: 5 Nov 2003, 05:14 pm »
Hi guys,
I just got off the phone with Paul of Stillpoints.  Essentially ERS can take upwards of 300 degrees before the polyester or adhesive starts to break down.
That being said,  I would not advise placing ERS too close to high voltage tubes.  Not because of the heat necessarily, but because of the fact that ERS IS conductive.
Cheers!
