FS: **SOLD** Custom 2m Ridge Street Audio Poeima!! RCA IC's
0 Members and 1 Guest are viewing this topic. Read 2105 times.
vman71
I have for sale a custom 2m pair of Ridge Street Audio Poeima!! RCA IC's.  Below is how Robert at Ridge Street Audio describes them:
"These I/Cs use 22 gauge solid core silver conductors. I believe it used three conductors in vertical weave: 2 ground and 1 signal. The insulators are the same material we use throughout our product line. If I remember correctly, the characteristic impedance of the cable is 100 at 1k Hz.
It's strengths are in the mid bass through the mid treble. Extension beyond that is adequate but not as good as say the current "P"!!! series, etc. It's presentation is open, very good speed and resolution without throwing everything in your face - it maintains good perspective as to how the overtones relate to the fundamentals...something a lot of cables don't do very well. It also maintains it's composure very well when a given mix gets busy - like big band stuff for example. It doesn't get noisy,compressed or congested."
These are a killer pair of custom made IC's.  I was going to use these with my John Hogan 300B SET but after listening, I knew it was too much of a good thing.  The SET already provides more than enough in the mid bass through the mid treble and needs help in the high and low extension.  If you don't have a SET amp but want that incredible midrange area, these are exactly what you're looking for.
« Last Edit: 23 Oct 2008, 11:04 am by vman71 »
vman71
Re: FS: Custom 2m Ridge Street Audio Poeima!! RCA IC's
« Reply #1 on: 15 Jul 2008, 03:30 pm »
BUMP...
If you want the SET sound but don't have a SET amp, these will certainly take you there.
« Last Edit: 8 Aug 2008, 06:20 pm by vman71 »
vman71
« Reply #2 on: 8 Aug 2008, 02:31 pm »
BUMP...$325
« Last Edit: 8 Aug 2008, 06:21 pm by vman71 »
Ridge Street Audio
Hello Ken.
As we discussed when you bought these I/Cs and as per the original invoice, these were a prototype of sorts custom made for another client. They are were not made according to any of the Poiema series design parameters. They had been used here off and on and were in excellent condition but they were not brand new as described above.
Nevertheless, these are very nice I/Cs but they are not out of Poiema series.
Cheers!
Robert
RSAD
vman71
« Reply #4 on: 8 Aug 2008, 06:26 pm »
Hi Robert,
Thanks for the correction.  These are not brand new and I've made the appropriate corrections to the add.  My apologies for calling them brand new (although the look like it).  They are, as Robert has put it, in excellent condition.
vman71
« Reply #5 on: 15 Aug 2008, 11:12 am »
BUMP...Pictures of the actual cables taken last night.  Don't miss out on these!!!
vman71
« Reply #6 on: 3 Oct 2008, 06:07 pm »
BUMP...and I'll make this silly good for someone $275.
