0 Members and 1 Guest are viewing this topic. Read 1500 times.
I know that the THX versions have a remote power on/off trigger. But I could operate the amp without using this trigger, correct?Also is there any difference in sound, level, input sensitivity?.Thanks,Albert
Quote from: leusink1 on 11 Jul 2008, 07:17 pmI know that the THX versions have a remote power on/off trigger. But I could operate the amp without using this trigger, correct?Also is there any difference in sound, level, input sensitivity?.Thanks,AlbertHi Albert,Originally THX required that you had to 'differentiate' the THX versions of the amplifiers from the standard amplifiers so we just added the triggers to set the THX apart from the non THX. After we decided not to offer THX amplifiers anymore we added the trigger feature to our standard amplifiers.The THX and the Non-THX amps have exactly the same performance.james
