Distance
0 Members and 1 Guest are viewing this topic. Read 2993 times.
cametz
Distance
« on: 10 Jul 2008, 10:23 pm »
I have RM2's. Is there a maximum distance from speakers to listener? The width of the room is 15' 4". I could make the room 26 ft in depth.
Thanks.
John Casler
Re: Distance
« Reply #1 on: 11 Jul 2008, 07:02 am »
Thanks.
The greater the distance from speaker to ear, the more effect the room will have on the sound.
That is, basic psychoacoustics dictates that SPL (sound pressure level) drops as you move away from the speaker.  This is primarily due to the sound dispersing.  This dispersion also creates room sound.
The reduced SPL's combined with the room reflections shape the sound.
So Nearfield would present the most accurate level of detail, and "direct" sound.
There is no real "maximum" distance, but most find that they find a distance that gives them the best combination of clarity and acceptable "room contribution".
That said, you will probably find the acoustic phenomena that moving nearfield will put you in the front rows of a performance "sound", and moving further away, will give you the impression of being further back in the hall.
 :scratch: Is that you Clyde?  Where have you been?
cametz
Re: Distance
« Reply #2 on: 11 Jul 2008, 10:39 pm »
Hi John
Best wishes to you.
I'll be moving the system from Fl to Ohio next fall. I plan to make a listening room in the basement and am in the beginning stages of gathering information.
Haven't been on any forums lately. Flying solo.
Clyde
superchad
Re: Distance
« Reply #3 on: 20 Jul 2008, 06:47 pm »
Hey where in Ohio?, I am in Salem here...................would be cool if you ended up sorta close, we have an "Ears and Beers" club and would be glad to add another!
cametz
Re: Distance
« Reply #4 on: 21 Jul 2008, 06:56 pm »
Hi superchad
I live in Warren, Ohio for the summer and to Fl in Sept. I'm trying to sell the Florida home but it very difficult. When we do I'll move the system to Ohio. I'll check in with you when it happens.
Thank you for the invite!
Clyde
Housteau
Re: Distance
« Reply #5 on: 22 Jul 2008, 02:21 am »
I grew up in Girard.
superchad
Re: Distance
« Reply #6 on: 22 Jul 2008, 05:19 am »
Heck you guys are right down the road, cmon over!
John Casler
Re: Distance
« Reply #7 on: 22 Jul 2008, 07:00 am »
Mansfield for me :thumb:
But now Clyde, Dave and I are "far" away = FLA, LA, and LA,CA  (I see some type of connection :scratch:) LA LA LA
Housteau
Re: Distance
« Reply #8 on: 22 Jul 2008, 03:40 pm »
Somehow I think that only you would have noticed this :).
John Casler
Re: Distance
« Reply #9 on: 22 Jul 2008, 05:15 pm »
Yes, and it was after midnight, and I really had to "reach" to get there.   :lol: :lol: :lol:
