Totem Mite's with Icon ?
0 Members and 1 Guest are viewing this topic. Read 3091 times.
RowanH
« on: 10 Jul 2008, 08:47 pm »
Has anyone heard of people using an Icon with Totem Mite's ?
I just received my Icon last week and am well impressed with this tiny little device. Of course it's all a slippery slope..
I'm currently using Def Tech ProMonitor 800's which I've nabbed temporarily from my media room and went listening at lunch today for some alternatives, the Mite's are a much nicer speaker - much better mid range, not as fatiguing on the top end. Definitely a lot more mid-low end punch.
Just shy of pulling the trigger, not quite sure why, maybe not quite believing the Icon will drive them :)
Rowan
Zero
Re: Totem Mite's with Icon ?
« Reply #1 on: 10 Jul 2008, 09:05 pm »
The Mite is a relatively easy to drive.  Provided that you aren't looking for bombastic dynamic range or aim to fill a large room with loud music, you should be fine.
RowanH
« Reply #2 on: 12 Jul 2008, 02:52 pm »
Thanks Zero for the reply. I have a feeling this is all going to become very expensive soon :)
