what did i do?
0 Members and 1 Guest are viewing this topic. Read 1453 times.
rosconey
what did i do?
« on: 3 Nov 2003, 09:10 pm »
while looking at the manuel for my dvd player i found a setting for 48khz sampling frequency or 96 khz if your reciever will handle it, well my rxv1 doesnt mention anything about sampling frequencies so i tried 96 for the hell of it, it sounded different somehow.
so then i decided to hook it up without the digital connection-used a set of rat shack rca's -it sounds better than ever/  so what did i do ? :o
Tonto Yoder
what did i do?
« Reply #1 on: 3 Nov 2003, 09:39 pm »
That's the audio equivalent of a colon irrigation--you've blasted out all the disharmonic detritus from your signal path and now things are smooth-sailing!! :D
rosconey
what did i do?
« Reply #2 on: 4 Nov 2003, 03:15 pm »
so whats this sampling frequency stuff-48/96
also does this mean i'm using the dac in my reciever now  :?:
or is the one in the dvd doing the work
Mad DOg
what did i do?
« Reply #3 on: 4 Nov 2003, 09:17 pm »
if ur connection between the dvd player and receiver is via the digital coax or optical input/output then u're using the receiver's DAC...if ur connection between the dvd player and receiver is via the analog RCA input/output then u're using the internal dvd DAC...
