CD transports
0 Members and 1 Guest are viewing this topic. Read 856 times.
lazydays
CD transports
« on: 10 Jul 2008, 12:39 am »
well I've now clobbered the second CD player since January!! Maybe this is an omen!! Anyway I'm back in the hunt for a transport or else something kinda decient for my bedroom system. Just something that sounds pretty good (yes I know it's still a CD) without breaking the bank. Anybody got any ideas and also what to avoid. Lastly anybody here have any experience with the Morrow CD players?
gary
denjo
Re: CD transports
« Reply #1 on: 10 Jul 2008, 01:18 am »
Maybe its a tiding to go wireless with something like the Squeezebox or other similar streaming device!  :D
Bemopti123
Re: CD transports
« Reply #2 on: 10 Jul 2008, 02:25 am »
I have a 47 Labs Shigaraki that I play with whenever I do CDs.  Nevertheless, whenever I get CD, I load it and rip it in my MacMini and I either listen to it in my Ipod or play it via an external USB DAC to my headphone set up.
In perspective, I think that the Shigaraki will be the last physical transport that I will have because I see that the end of the physical CDP is coming.  The only reason why some CDPs are made is for overseas consumption, as many Audiophiles have embraced PC transports fully.
Most affordable CD transports will have their compromises and I just do not see myself dishing out 1K or more on a physical transport that is bound to fail sooner rather than later (many newer transports use CHEAP mechanisms that simply have a finite lifespan), thus you sort of have to wonder why pay for a chassis.
If you have not tried a PC based solution, you should try.  It will cost nearly as much as a midrange CDP transport.  If you have your own DAC, it will be cheaper.
I say, when it comes to PC based transport I would AVOID wireless set ups from the beginning, hardwiring the computer to the DAC will guarantee that you will have 0 frustrations when signals go missing or you are having hard time make the sound stable.  In my opinion, the most direct relative to a physical CDP is a hardwired PC based solution.
