RE- Ps UO
0 Members and 1 Guest are viewing this topic. Read 1273 times.
heatedglass
RE- Ps UO
« on: 7 Jul 2008, 09:31 pm »
Hope all had a good 4Th. Last week I asked for anyone who felt like they experienced any negatives with the PS Ultimate Outlet. DSK responded with a simple explanation on what I was hearing and also not to plug the amp into the UO. I did what DSK suggested and found the UO is not causing any negative effects and with some adjustments to speaker placement the system sounds better then ever. Again thank you DSK. For any interested as a test to the dynamics of your speakers at a volume level starting at -10 work your way to where you feel comfortable, listen to (Flim & the bb's Trycycle) The song trycycle will tell you something about the dynamics of your speakers. Absolutely stunning.
Gino
DSK
Re: RE- Ps UO
« Reply #1 on: 7 Jul 2008, 09:37 pm »
Glad it worked out for you Gino.  :D
