cart set-up on a Rega
0 Members and 1 Guest are viewing this topic. Read 1688 times.
2bigears
« on: 4 Jul 2008, 06:13 pm »
can anybody please point me to a two point Wally type alignment tool for the P9-1000 arm.where do you guys get these,are they machine specific,as one size don't fit all ????  :scratch:  thks  :D
Wayner
Re: cart set-up on a Rega
« Reply #1 on: 4 Jul 2008, 06:22 pm »
If you can supply me with the following information, I can make you a 2 point location card.
I need to  know:
1. Overall length from arm pivot to stylus.
2. Overhang (from turntable spindle to stylus)
3. Offest angle (in degrees)
The card I can make will be printed in color on a 110 lb card stock paper and will dial you in.
It will look something like this:
Wayner
2bigears
« Reply #2 on: 4 Jul 2008, 07:10 pm »
:D  thks. not sure i can get those measure points,but those cards you make look sweet. why the heck would Rega not supply one is way out there ???? :duh:   are the Wally tools tt specific,or are they generic ??  :D
Scott F.
« Reply #3 on: 4 Jul 2008, 08:54 pm »
Actually if you are using one of the Rega arms, they have specific protractor that they should have sent you home with. I've got a copy that I could PDF and email to you. You can print it out on a manila file folder and use it that way.
lemme know  :green:
TONEPUB
« Reply #4 on: 4 Jul 2008, 10:16 pm »
Forget about the Wally tools.
That guy will take your money and never send you anything.
In a pinch, you can set a Rega up pretty well with a Geo-Disc actually.
