Denon S302??
0 Members and 1 Guest are viewing this topic. Read 1268 times.
chgolatin2
Denon S302??
« on: 4 Jul 2008, 04:17 am »
Does anyone has the Denon S-302?  Pro's Con's experiences?  :scratch:
Thanks~!  :thumb:
JP78
Re: Denon S302??
« Reply #1 on: 11 Jul 2008, 05:14 pm »
it's really a great piece if you're going to hook an ipod up to it often.  if you don't really plan to, then it's still a good unit :).  easy to use, sounds clean...basically it's very capable as an intended plug n play solution.  i know a few other companies make em out there...integra (as mentioned eariler), jamo, and i believe sony too.
if you're planning on using the denon's remote as a universal remote, be warned its a little clunky to use...especially if you have a dvr+hd cable box.
best,
jp
