Bugle DC offset into the danger zone
0 Members and 1 Guest are viewing this topic. Read 1554 times.
MrRalph
« on: 3 Jul 2008, 05:29 pm »
Finished my Bugle, updated my measurements without input or output connected. Measured +- 9.23V on -VE (4) and +VE (8) on U1/2/3.
DC offset for Out1 (1) and Out 2 (7) is:
U1: 150mV
U2: 1700mV
U3: 150mV
What could be wrong or what should I test?
Any tips are highly appreciated!
Ralph
« Last Edit: 4 Jul 2008, 06:13 pm by MrRalph »
hagtech
    • http://www.hagtech.com
Re: Bugle DC offset into the danger zone
« Reply #1 on: 10 Jul 2008, 04:44 am »
That sounds awfully high.  1.7V is about 100x too much.  Could be a very leaky 0.22uF coupling cap (did you use PIO?).  Maybe wrong resistor value or you used a different opamp.
jh
MrRalph
« Reply #2 on: 10 Jul 2008, 12:53 pm »
I'm very sure the resistor values are correct. For the capacitors I'm using standard new Wima MKP4/10 capacitors. The op amps are NE5532's.
Ralph
